New to the domino, and this group(hello to all). Finally made the purchase, a DF500. First project(after some practice) will be a dining table. Will the 500 with the 60mm domino be enough to attach the stretchers to the legs. Initially planning on using 1”X4” for stretchers. The legs are Turned with 5”X5” at the top. Will the 60mm out of the 500 be enough, and if so how many dominos would you use per joint? Or would I be better sticking to a tradition M&T joint? Thanks in advance.
