I just finished my new circle cutting jig for the OF1400 (If festool wants the design let me know!)
The ideal is when cutting circles using any of the current jigs for the OF1400 (trammel, MFS700) I have run into problems. With the trammel, if you have the dust collection hose hooked up it gets wrapped around the router along with the power cord as you make your cut. (Personally I have not been able to get it to work with my OF1400 at all!)
With the MFS you have to deal with the bulk and it's a real pain to use if you have to make more then one circle cut AND if you just need to cut circles it's alot of money just to do so.
So I took it into my own hands to make the perfect jig for the OF1400.
I used a 9mm thick 6" X 12" Plexiglas, a bearing with an inner diameter of 30mm and a pivot from another circle jig.
Knowing that the outer diameter of the bearing was 42mm I routed out a 7.5mm deep hole 42mm in diameter. The bearing fit in very tight which is what I wanted.
Then I drilled a hole in the center of where the bearing sat and using a flush trim bit cleared the area in the center of the bearing of the remaining Plexiglas (1.5mm)
I made a channel for the pivot point to slide in when changing the diameter of your cut.
Now that I have it finished I can just attach a 30mm copy ring and place it in the bearing's center and cut!
Check it out while I make circles one handed holding the camera with the other!
Oh I'm righthanded and thats my left hand on the router. I think that says alot about this router and my jig!!
