paul_david_thomas
- Aug 29, 2008
I was a little bored today, attempting to avoid tiling a bathroom, so I thought, based on the fact I feel my MFT/3 is a little small and they (FESBOYS) don't seem to have done a stand alone table - nor do I have space for it, I thought I would attempt to do a leaf with some 25mm MDF. This was my first and it fits like a glove - ok, I need to make a few 1mm adjustments here and their and it will be spot on. The next one I will incorporate clamping - like the knobs you get in those flat clamps that work with the MFT/3.
As I had the MDF lying around, this was pretty cheap and means I can now move the drop guide further up the table to let me put larger peices on. I will build two more of these, one for the side and one for the rear.
You can also see I've got two "angle" adjusters on the straight edge - I borrowed the other from my CMS unit, works fine and means their is no bend on the the Alu when you push large/heavy material against the Alu...
These pieces slot onto anyside in about 15 secs. I'll see how it goes and see if I need any addition support, but I should not. The main load goes down the table...
Paul.
Paul.
