Steve1
kevinculle said:Jointer first...a planer will create a parallel face to an existing flat surface. The jointer creates a flat surface where there was none before.
Not necessarily.
You can joint on a planer (except for making an exactly perpendicular edge), by putting the board on a sled and shimming the high spots. I typically use a few dabs of Bondo, or sometimes painters tape if bow is small, others use wedges, hot melt, or probably countless other methods.
I have a jointer, but often, this is my preferred method for long boards, or if my board is already getting a bit thin and I want to just take off the minimum possible, or if the board is wider than my jointer.
