Does anyboby have a link for a video Kapex UG set up?
Chris Hughes
Just made the leap.Iet up last night but was not very satisfied about the stability of the UG wings.  Seems like they need to be adjusted to make contact with be base.
If the wings aren't solidly connected to the saw, you haven't made the connection correctly.
There is a piece of punched sheet metal on the bottom connected by a thumbscrew that has a spring. You have to hook the wing on the v-groove, loosen the thumbscrew, push the sheet metal piece all the way toward the saw, and then tighten the thumbscrew.
If you get it correct, it makes a very solid connection. If you get it wrong, it makes a false-solid connection that isn't solid at all. In fact, it's very sloppy.
Please let us know if that's the issue.
