Dog House - MFT/3
Somewhere to store bench dogs when not in use in a space on an MFT that doesn't get used for anything...
More flag stops? I have 9 stops over a distance of 8', but I've read on here about someone with 25 to 30!
I think they have something like 8 MFT/3 tables and 24 guide rails - and I thought I was a Festool nut with 2 MFT/3 tables and about 8 guide rails...
I got 8 stops, I need to buy 2 more just to have more then you
Heheheheheheh I'm a badddd maaaannnn
Woodwork Wizard said:
Made using the LR-32 system which makes the perfect spacing.
Are the holes loose? What bit did you use?
Personally loose is better so they slide in and out easier. I use a SYS-3 with an MFT top, that has a rack inside for dogs. More of a "dog house" even ;) Holds all my clamps and saw accessories too while being portable.
Peter C,
The holes were cut with a Festool 20mm bit 491072. It's been good for maybe 400 holes so far...
