marty schlosser
- Dec 7, 2007
Fellow Domino 500 owners & experts,
I'm an experienced Domino user who has recently noticed an alignment problem with the fence that I'd not heard of before. This mis-alignment results in the slots being made out of the vertical axis. This poses a problem when I need to use the narrowest (13mm +) dowel-hole width setting, which is what I prefer to use most of the time.
The alignment problem with the fence is observable when viewed from above the machine which you can see from the attached photos. There is a .5mm gap between the fence and the body on the right-hand side, whereas there is none (or virtually none...) on the left-hand side. That's why the bit isn't plunging vertically. I am not sure if this is a result of the fence having warped through the tightening action of the fence horizontal clamping lever, or what. Regardless, the fence is clearly warped. The gap becomes more pronounced the higher the fence is raised.
Any assistance would be greatly appreciated.
Marty Schlosser
Kingston, ON, Canada
Ph 613-766-8270
Marty Schlosser
Ph 613-766-8270
