It is possible that this question has been already addressed, however I couldn't seem to find a search function on this forum.
I have a newly purchased Domino 500. It comes with a 5mm bit. According to the manual, the max cut depth is 28mm. When I attempted a 28mm test cut with the 5mm bit, the end of the shaft burned the top & bottom of edges of the cut. The obvious reason for this is that the diameter of the cutter increases toward the mounting point.
I have two problems with this. (1) I cannot find in the documentation where it states that there are differing maximum depths for different cutter diameters, and (2) I cannot understand why this insanely expensive tool wasn't designed such that the advertised max depth would be available for all cutter sizes.
