yetihunter
- Apr 21, 2013
Get the 700.
smorgasbord said:This is a handy chart showing which machines can cut mortises for which tenons:
[attachimg=2]
Note that it doesn't cover the newer small connectors designed for the 500. But, since they're 8mm I would think that the 700 could be used as well.
So, the 700 only doesn't do the 4mm, 5mm, and 6mm dominoes. And while the 500 does 8mm and 10mm, it only does them at the shorter 20mm/25mm depths, which is fine for alignment but maybe not strong enough as a replacement for traditional mortise and tenon joinery in frame and panel joinery or table apron to legs, etc.
On the other side, if you're doing 4mm dominos for alignment, biscuits are the same thickness and will do that job as well. And, if you're going to buy 2 tools to cover the range, I'd argue that a 700 paired with a Lamello Zeta P2 is the more versatile combination. The Lamello P10 knock-down connectors are also more stealth than the smaller Domino connectors. For the few times you really want that 5mm or 6mm joint, the Seneca adapter (with clip on depth limiter) would suffice.
This isn't to say that the 500 isn't right for some, or even most people. I have done entry doors in the past, and may again:
woodbutcherbower said:That’s stellar work. I do the same maybe a dozen times a year. Proper mortise & tenons every tine for me though.
rp127777 said:Thanks everyone for your input. As I am a hobbyist and to answer some questions, at this point I don't have a specific need or project. I think it is more of a want than need at this time. Since my retirement last year, I am tooling up as I do projects around the house and get more into woodworking.
JimD said:Snip.
With a 700 you can do big or little projects, with a 500 you are limited to little ones.
gxgn said:I had this debate years ago and I ended up getting the 700 plus the Seneca adapters for 5 and 6mm. I found myself using only 5, 6 and 8mm cutters so now my 700 is for sale (or trade locally). ... Now I’m tempted to try the Lamello Zeta P2 plus the 500 if budget will allow, probably totally overkill for small house projects I do.
