I'd appreciate information on the use of the Festool Domino. I am making some simple wine storage cases out of 5/8th inch fir plywood and was using the domino to join the various components and using the Domino plate from Ron to set the positioning of the dominos. The Domino size was 5 x 30 mm and the depth setting was 20mm for the end plunges and 12mm for the face plunges. The set up with the Domino plate was very simple and everything appeared to be going well until I attempted to join the pieces together and then I had trouble fitting the dominos in the slots and the boards were approximately 3mm apart. Further investigation revealed that the 5mm bit had broken at the tip and was about 3-4 mm short. I replaced the bit (fortunately I had the extra bit in the systainer/bit kit) and started redoing the domino slots. After about 80 slots the bit again broke at about 3-4 mm from the tip.
I am looking for advice as to why the bits broke.I suspect it has to do with my technique since it happened twice and I'd like to learn from my mistakes.
