Domino d500 switch problem
D1llig4f
Hi, my domino power switch has stopped working, when I slide it forward into the ‘on’ position nothing happens. I took the casing off to see if I could see any problem and on inspection found that there is a push button type switch inside that is supposed to press in to activate the tool. When you push the power switch forward it’s supposed to slide over this button and press it in to activate the tool but my button is bending over instead of pressing in. I’ll probably just tackle this repair this myself but wanted to double check I’ve got the correct part from the ekat website before I press ahead and order it. I think it’s part number 89
Regards
William
Looks like it. Giving Festool Service a call might reassure you to get the correct part.
