Samurai Dave
- Jun 13, 2008
Here's what I did: (double-click images to enlarge for a more clear view)
1 ) Disengage the fence from the motor (as if you are going to change a cutter bit)
2 ) Locate the black plastic Limit Stops
[attachthumb=1]
3 ) Notice the retention "lip" on the Stop
[attachthumb=2]
4 ) With a pair of padded pliers (or wrap tape around the teeth) slightly lift up the front of the Stop to clear the retention lip. Pull back.
[attachthumb=3]
5 ) Here's what the Stop looks like after it has been slid backwards. Remove them.
[attachthumb=4]
6 ) The fence can now be slid up and away. Put the other Domino parts far away, so metal filings don't get onto them.
[attachthumb=5]
7 ) File the face of the arresting surface FLAT with a fine metal file. Be gentle. The aluminum is soft and will gouge easily. It doesn't need to be completely shiny, just the majority of it. (Now is NOT the time to be getting out the belt sander and using it instead of a hand file. Too much metal will be removed, and you'll have a frowny face.
) Filing at this angle helps mate with the teeth on the fingers that apply pressue to arrest the movement of the fence. You may be tempted to run your finger along the surface to test for smoothness, but resist this temptation. You finger will deposit skin oils on the surface of the metal, defeating the purpose of this whole process.
[attachthumb=6]
8 ) While we have it disassembled, the sides of the base have some flash on them that prevent the Cross Stop accessory from snugging-up against the base properly.
[attachthumb=7]
9 ) Gently file each side of the base plate. Keep the file square to the surface. Again, it doesn't have to be completely shiny, just the majority of it.
[attachthumb=8]
Blow/wipe ALL filings away. (The last thing you want are problems caused by metal chips!) Reassemble, and you are good to go.
If the Festool folks are looking for suggestions, adding these few steps to your process at the factory would make an already impressive machine close to perfect.
UPS had just delivered my Domino today. 8) I had been forewarned by several posts on the FOG about the fence slipping, so that was my first order of business. Upon examination the explanation is pretty clear. I have a fair amount of metal working background, and I can see the issue. The surface of the fence being clamped is a raw aluminum casting, which has oxidation (which rubs off easily, acts like a lubricant). Also the part has been machined which means it has taken a bath in coolant (cutting fluid) which contains mostly water (to cool the cutting bit and remove swarf) and some oil to keep down rust on the machine (the CNC mill, not the Domino). To expect the movement of the fence to be arrested with those strikes against it is a very tall order. I clamped the fence, right out of the box, to maximum pressure. I then applied some downward force and the fence slowly slid downward, as suspected.
Being one of those kids that always disassembled things (but then had problems putting them back together
) I couldn't resist attempting a fix to this otherwise wonderful machine. (I have improved my rate of successful reassembly over the years...)
After the simple filing, I clamped the fence and applied downward pressure. No movement!
Then I really LEANED on the fence, still no movement. ;D You may have to adjust the clamping pressure by backing-out the screw and moving the lever a few notches. I adjusted mine 2 notches and have plenty of clamping pressure now. Can't wait to actually make some cuts and install some dominos!
[attachthumb=1]
[attachthumb=2]
[attachthumb=3]
[attachthumb=4]
[attachthumb=5]
[attachthumb=6]
[attachthumb=7]
[attachthumb=8]
