Domino hookup to non-Festool vaccuum.
ajkelsey
I need to attach a shopvac with 2.25" hose to a Festool Domino.  I will need a flexible smaller diameter hose and an adapter to connect it to the shopvac.  Do you guys know where I can find these items?
You could start by downsizing the shop vac hose with a 1 1/4" shop vac hose. That would probably make it easier to adapt and also lighten the whole set up. Another option would be to get a Festool hose. The Festool hose vac end will fit a regular shop vac.
you can also get the fein rubber step adapter for about $5.  it allows you to use your existing shop van hose and connect in to the domino.
I use the Porter Cable 73333 Collection System hose with my shop vac.  Works great with my Domino and Carvex.
I think it sells for about $35 on Amazon.
