Tombstonetommy
- Mar 2, 2017
I am in the market for a domino joiner but which one do I go for
Any advise would be welcome
Tombstonetommy said:I am in the market for a domino joiner but which one do I go for
TXFIVEO said:I suggest the DOMINO XL.. does everything the 500 can do (with Seneca attachments) AND allows for much bigger joinery. The 500 can't do both where the XL can. Simple choice for me.
ChuckM said:The decision is like getting a van vs a bus. If most of my trips were done with 6 passengers or less, I'd choose a van (DF500). For the few occasions that I needed to transport 30 people, I could rent a tour bus. It is tiring, fuel-inefficient and high maintenance cost (not to mention parking issue) to drive around town daily in a coach bus with only a handful passengers in it.
Please advise us what kind of projects you want to do with it.Tombstonetommy said:I am in the market for a domino joiner but which one do I go for
#Tee said:the more expensive one is more capable of larger projects and does everything the smaller can.
Midnight Man said:#Tee said:the more expensive one is more capable of larger projects and does everything the smaller can.
Whilst I don't yet have a Domino, I am researching them right now as I am planning to buy soon. In my research, I discovered that for smaller items (for example, desk drawers), where one might be using 12mm thick material, it would be recommended to use a 4mm Domino.
From my understanding, the DF700 can only go down to 8mm minimum thickness.
If my understanding above is correct, it would seem that the choice of which of the two Domino units to buy could be quite important, and would largely be dictated by what the user wishes to build?
RNEMTP said:There are adaptors made by Seneca that allow the 700 to use 500 cutters.
