Mellowfellow
- Apr 5, 2021
I'm new posting to this forum, so hello everyone!
I've got a project going and the stock cut, but I'm undecided on how to proceed. I own an XL Domino and have some 12 and 14mm dominoes. I've got 2x2 nominal or more precisely 45x45mm oak for this.
So where I am stuck is how I join these corners.
The top bit at the front will have a 100x20 skirting going around to hide it neat, so whatever I do there doesn't really matter other than has to be strong. Middle will be half lap + 2 screws with plugs hiding it. the bottom corners, once again I'm undecided, they have to be stable to stop racking.
The top bit is quartz sink unit joined from two, so you can see where the joint is in the picture. 6 legs in total of the unit, 2 under the seam to support it flat. Under the quartz counter/sink unit I am using 18mm plywood, which will be hidden by the skirting boards.
One of the bigger problems here that I have is the fact that I can put only one domino in the top corner and then it goes only 25mm into the leg because there's two of them.
I can't really clamp them on the long end as I don't own a pipe clamp. there's a chance i could source a ratchet strap, but I'm not convinced about that either.
I've tried drilling 3mm hole and putting in screw through the domino to secure it mechanically like you would mortice with a dowel. Technically speaking it "works" in a sense that when I will glue it it won't come out, but it doesn't pull the joint together. It wouldn't matter very much visually as it will be mostly hidden, but the bottom joints will be visible, and the gaps in the joint certainly don't make it stable. I can get them pretty stable with stretcher plates that are used for countertops, but then is that OTT?
Hope this all makes sense. And ideas or advice will be appreciated.
Thanks!
Thanks!
