Hey Everyone,
I have the Domino DF 500 and I am very new at using it. I am trying to make a butt joint with 3/4 birch plywood. What domino should i be using 5 or 6mm and what is, if there is, the rule of thumb for determining what domino size to use for the stock thickness you'll be using ? I am thinking of using the 6mm because i would plunge 12 mm in to the face of the 3/4 plywood and then the long board I would plunge 28mm to get a total of 40 mm the length of 6 mm domino. I was originally going to use 5 mm but noticed i would have a considerable space on the side of the board since you can only plunge with a handful of depths. Is there a rule on how much of the domino should be inserted on the wood for a secure joint ? Sorry if this at all confusing, but I will clarify if needed. Oh and I am making an arcade cabinet so i do want a considerable amount of strength. Also how many dominos should i be using or how should one determine this ? Thanks for all the help guys.
Kind Regards,
Ted
Kind Regards,
Ted
