Hi Folks,
I am new to the board and recently purchased a Domino. In an effort to ease the tight fit between mortise and loose tenon, I further rounded one of the rounded sides of the tenon with sandpaper which made the fit easier. However, I noticed that if I removed only slightly more material, the fit quickly becomes too loose. I believe the reason is due to the thickness of the flat cheek of the loose tenon is actually not thick enough to achieve a snug fit within the mortise. This looseness is evident if one inserts an unmodified tenon obliquely without fully inserting the tenon to test the fit of the cheek to mortise. This looseness was observed fitting multiple loose tenons in multiple mortises.
This rather loose fit concerns me as a traditional mortise/tenon fit between the flat wide cheek to mortise should be snug. It appears the tight fit of the Domino joint is due to the tightness of the rounded sides of the loose tenon against the rounded portion of the mortise. I am also concerned that the tight fit of the Domino system does not allow enough glue to be applied to achieve a better bond between the flat cheek and the meatier portion of the mortise which is on the loose end to begin with. Furthermore, in rail/stile construction, if the tight fit of the mortise/tenon within the stile is between the rounded portion of the loose tenon and the rounded portion of the mortise and not between the flat cheek and the meat of the mortise, then the joint is more dependent on end grain adhesion within the stile. This problem should be less of a concern in the rail. Could this be the reason the Domino did not test better in the discussion of the article comparing different joints posted earlier?
Has anyone else had similar experiences or did I end up with a too-big bit or too-small loose tenons. Should I be concerned with these observations? For now I still round one of the rounded ends of the loose tenon to allow more glue to be applied which is a real PITA. I may eventually resort to making my own loose tenons or try another tenon supplier. Any thoughts would be greatly appreciated.
Dan
Dan
