Iceclimber
- Oct 25, 2014
First i should start by prefacing this with my motivation for purchasing either of these machines. I am about to make seven shaker style doors out of some very very beautiful bubinga i purchased yesterday.
Original i was going to do the whole project for the most part on my CMS router table. Originally i was also going to use African or Honduran Mahogany. After finding a less than desirable pile of African Mahogany coupled with feeling morally bankrupt purchasing real mahogany i strayed and purchased the nicest boards on the shelf. Ou know those ones that you just gotta have even if they are not what you came for and cant afford them. Instead of 40BF of 4 and 5/4 African Mahogany i ended up with 40 BF of near perfect 8/4 bubinga.
So back to construction of these doors and what tool to use. Like is said at first i figured the CMS would get the job done just fine. I am now thinking this wood is both rock hard and massively heavy! The tiny little mortis and tenon joint i will get on my CMS is seeming pretty inferior all the sudden. Really quite a bummer as the money has been spent on the lumber and i really only set aside enough extra to purchase a door cutter set for the router table.
Regardless I'm not going to start cutting up this beautiful wood knowing I'm going to build something in a half assed manner. So the question is Domino or mortising machine. The reality is sooner or later i will end up with both tools. However right now i need the tool that will see the most use. For this project i also need to edge joint 3/4 finished boards to make 3 end panels for cabinet carcasses much like you would see in a high end stain grade grade kitchen enclosing a fridge.
Beyond that i have two exterior doors to construct come spring. Both those will have have 1-3/4 styles and be made of probably solid teak.
I am inclined to just purchase the domino. On the other hand I'm a bit of a purist and it really feels like cheating to me. The flip side of that coin is i also don't have to try and cut tenons on either my job sight table saw, band saw or CMS. I also can edge join those side panels for the cabinet boxes perfectly and not have the problem of how to get them perfectly joined. Well i guess i only have a 6" jojnter so unless i want to join all 6" or less boards i will need to hand plane the finished pannnels.
Anyway the real question is can i do 2.5 x 3/4 door styles and edge joint 3/4 stock with a Domino XL if i buy all the seneca adapters. If not i am inclined to get the mortising machine as i need something that can cut large and small mortise alike for my first purchas.
