Domino Plate threaded holes
lunchman
Hello all.  I noticed this morning when I was attaching the Domiplate to my DF500 that it wasn't sitting flat on the sole plate. When I removed the thumbscrews holding the Domiplate in place, I noticed that something had backed out of the threaded hole on the Domino plate. It's a small spring that appears to provide the threading for the holes.
Question is: how do I get this back into the plate? Does it screw back in? Or should I try to tap it back into place?
-Dom
It sounds like a Helicoil.  It should be screwed, not tapped, back in.
It bad news is they're normally installed using a tool to wind the spring tighter.  You may be able to improvise.
Good luck!
Andrew
That's not good...I'd just send it in to Festool for replacement.
I've installed hundreds of Helicoils in motorcycles because of needing a durable thread in aluminum castings. As [member=6802]Roseland[/member] said, these are installed on a "winder" which reduces the od of the insert and allows it to be screwed into the tapped hole. Once in the tapped hole, the winder is reversed, the Helicoil expands and a tang on the bottom of the Helicoil is broken off and it contacts the inside wall of the threaded hole and becomes the anchor for the Helicoil.
I have on occasion experienced the same thing on a motorcycle. If you can get a pliers on a part of the piece that projects from the hole, you can carefully uncoil/unwind (not unscrew) the insert and not damage the internal threads, however then you'll have to install a replacement Helicoil which they sell in quantities of 10 each and you also have to purchase a winding tool for installation.
So you're probably looking at $50 in parts...that's the reason I recommend sending it to Festool.
Thanks, guys. Looking at helicoil insertion videos on youtube showed the normal method of inserting these with the break-off tang. I can grab it with needle-nose pliers and screw it in part way but can't get it to go any further. If I could somehow duplicate the tang by securing the helicoil to the thumbscrew and screwing it in as a single piece.....  If the Domiplate knobs weren't so large I could perhaps work from the other side and pull it through. I don't have any metric equivalents on hand to give this a try.
I guess in the meantime I'll use the Domino fence rather than the Domiplate.
Kind of an odd setup for Festool to use on the Domino plate - helicoils.
I've always had to finesse the Domiplate into position - as if the holes were off by just a little bit.
Festool don't make the Domiplate its an aftermarket add on that Seneca make.
The helicoils aren't in the Domiplate. They're in the sole plate of the Domino itself. I was somewhat surprised by this when I took a close look at the holes.
-Dom
Think he means what he said fella. Domino plate vs Domiplate.
Actually, it's not odd but rather the perfect application for a Helicoil. The Domino base plate is either an aluminum alloy or a zinc alloy and quite thin. A Helicoil is stainless and will provide excellent screw retention for the life of the Domino.
Had Festool not installed Helicoils, the base plate would probably be trash after inserting and removing the screws 50-75 times. Each time the screw is torqued down the thread form in the base plate is being distorted a little bit. If it's just a soft alloy material, it distorts, distorts, distorts and then finally just strips out.
Right on cheese, it's exactly like that.
We used to glue in the helicoils with locktite 'red', super reliable.
Your explanation makes perfect sense re: the material used in the Domino plate.
Thanks to all on the helicoil lesson. The problem is resolved. I went down to my local Consumers Auto Parts store and purchased a helicoil insertion kit - worked like a charm and I'm back in business. The size for these is M5. And if it ever happens again, I've got enough helicoils to last me a good long time.  [smile]
Back to cabinet making for me.
-Dom
lunchman said:
Thanks to all on the helicoil lesson. The problem is resolved. I went down to my local Consumers Auto Parts store and purchased a helicoil insertion kit - worked like a charm and I'm back in business. The size for these is 5M. And if it ever happens again, I've got enough helicoils to last me a good long time.
-Dom
Thanks for the feedback on the insert size Dom...that's good to know.
I'm glad you were able to resolve the issue yourself. I never know the skill level of the individual I'm trying to help, so I'm glad you took on the task and brought it to successful fruition. My neighbor is one of these guys that always wants to fix things but only succeeds in making things worse. His desire is in the right place, but his skill set is somewhere in left field.
Birdhunter said:
I watched a couple of videos on the helicoils. Very neat!
Could they work in wood?
That's an interesting idea...they probably could if you epoxied them in place.  [big grin]  This could make for a very interesting application.
These inserts are usually used instead because they're readily available and certainly cheaper than Helicoils.
It would have been interesting to find out if Festool would have honored the warranty given that it manifested during use of an aftermarket accessory.
