Birdhunter
- Jun 16, 2012
I almost nailed my hand yesterday using (misusing) my Domino and wanted to share what I learned.
I was cutting a series of mortises into the narrow edge of 3/4" boards using a #5 cutter set at 20mm. The boards were 1 1/2" across. I positioned the Domino on each pencil mark and, holding the board against the Domino face with my free hand, cut the mortise.
No problem.
I then had to cut a series of mortises at a depth of 40mm into some 3/4 by 2" boards using the same technique.
No problem.
I realized I had missed cutting a mortise with the 20mm setting.
I grabbed the board with the missing mortise, held the Domino on the pencil mark and the wood against the Domino fence with my free hand. Just before I started plunging the Domino, I realized the cutter would be below the wood and, potentially, hitting the hand holding the board. I had not reset the fence from 40mm to 20mm.
I put the Domino and the board down on the MFT, walked out of the shop, and thought about how my sloppy technique almost cost me a trip to the emergency room.
I'm exposing my dumbness in the hope that no one repeats my mistake and hurts themselves.
No problem.
No problem.
