So I just picked up the Domino XL and for my first big project am making a large outdoor white oak table. The slats for the table top will be 174mm wide by 45mm thick. The thickness calls for a 14mm tenon, but the width complicates it. Factoring in double the tenon thickness between dominoes as recommended by Festool, 3 dominoes would leave too little substrate at each end of the board, while 2 does not seem strong enough to me. I could use 12mm and fit 3 dominoes comfortably, but they seem a little too thin. Am I just over analysing this? Thank you all for any input you might have.
