Domino shelf connectors
neeleman
Finally there's a third party accessory for the Domino DF 500.
It's called Zuzzel shelf connector and made in Switzerland.
There's also a drilling template and Domino depth limiter available.
It's the same system as the Mini-, Maxifix or Rafix connectors but now it can be done with the Domino.
Still have to find a supplier or online shop in Europe because the Shop button on the Zuzzel website doesn't work.
[attachimg=1][attachimg=2]
They look pretty slick.  It will be interesting to see the cost on these.
It is always good to have RTA options and I am glad to finally see one available for the Domino.  I may try some if they become available in the USA but it looks like its a lot more finicky install than my current method using the Lamello Clamex P.
What would be the benefit of these over a standard eccentric connector?
I think that the plate with two screws in it would provide better pull-out resistance and also less likely to work itself loose with racking motions.
