G guitar_ed Member Joined Aug 28, 2012 Messages 86 Mar 8, 2015 #1 Hi, My coffee table design is such that I can use either one 8mm x 40mm domino, or two 5mm x 30mm dominos at the corners. My inclination is use two 5mm x 30mm dominos. That it would be stronger & more stable. Any thoughts? edg
F festup Member Joined Jan 10, 2008 Messages 40 Mar 8, 2015 #2 What are you joining? Is it a rail to a leg? If so, I'd use 2 5mm across the width. Two will resist racking force better than one. If it's side by side, I'd think one 8mm would suffice.
F festup Member Joined Jan 10, 2008 Messages 40 Mar 8, 2015 #4 Then 2 would be better. I used 6mm on this sofa table. Attachments image.jpg 816.3 KB · Views: 469
