I understand that the domino thickness should be about 1/3 the thickness of the material being joined, but what about the length of the domino. If for example two boards 5" wide are joined together with dominos, what should the length of the dominos be ?
I am considering the Domino 500 vrs the Domino XL 700.
95 % of the work that I do could be handled by the 500, although I would like to attempt joining boards with dominos longer than the 10x24x50mm dominos.
My question is: Has anyone tried cutting a domino slot with the 500 then hand drilling (with a 10mm drill) a deeper slot and custom cutting the beech domino stock to what ever length of domino is needed ?
