Brice Burrell
- Mar 13, 2007
CDM said:Okay, I just did that. To me it looks like both pieces go in a slot on the underside of the guide rail, get fixed in place by turning levers, and then the end of the big one can be moved a little by squeezing the green trigger. So basically it's kind of like having an MFT-top quick clamp under a rail.
Two questions...
How thick does a board have to be for at least the small side to clear a surface underneath?
On a board with parallel edges, how far from perpendicular can you clamp the guide rail before the round rubber end pieces no longer provide a firm grip?
You've got the clamp figured out. I don't remember off the top of my head how thick the material need to be to clear. (I'll check later and add it to this post) You can over hand the end off a table of saw horses where you place clamp ends on thin material. The one thing to be careful of with thin material is that you don't bow the material when you clamp the rail down tight. You can get some angle before the clamp won't grip anymore, but honestly not a lot. It's been a while since I've tried so I don't remember exactly how much.
