Domino to build plywood cabinet?
Kevin,
I think that the concern about flowing out the face is when he would be using the domino to do the shelves to the sides.
I can see that being a concern. When using plywood I do not feel the 1/3 thickness rule for tenons really applies due to the ply being the weak link vs solid wood.
One trick I use for shelving is to reference from the bottom of the Domino vs using the fence. You can then lay out the shelf on the side of the case, clamp it in position, and plunge both mortises without moving the workpiece.
I have used both 5mm and 6mm to attach shelves (tops or bottoms also) to plywood sides.  I too have debated  whichis a better way to go size wise.  I tend to use 6mm havn't had any problems yet.  The 6mm allows  for use of the 12mm depth  setting  for the face mortises which leaves about 6mm as opposed to the 3mm left when using the 15mm depth for 5mm Dominos. 12mm face, 28 mm end.  I do see the concern for removing too much ply thickness with 6mm Dominos but so far so good.
I have also used the 12mm face with 15mm end depths for 5mm Dominos , by triming a little off the lengths making the 5mm Dominos about 27mm long.
One trick I use to avoid plunging the Domino through the face  on the wrong setting is to do all the face plunges first. I am a lot more likely to check the set up settings  when I get the Domino out to do the first set up than  in between tasks. That way you do the shallow ones first, if you forget to change .... no big deal.
I draw layout lines on the face... shelf center line  across the cabinet side,  and a "vertical" Domino center line forming a cross to align the fence on.  I usually add a parallel line 10mm  from the center line. 10mm is the distance from the bottom of the Domino machine to the center of the mortises regardless of the Domino size. I use this to reference a straight edge clamped to the work piece. Effectively making a fence to  push the Domino against . Really helps stabilise it for the face plunges. The straight edge does the function of clamping the shelf to the cabinet side , as davee, and Kevin S. suggested.
Some of the layout I do may be overkill , but it gets good results and helps avoid mistakes.
Thanks everyone for all the tips and info.  I worked on it today and the 5mm worked fine in the 3/4" ply.  I was real careful about not going too deep into the face sides of the ply.  Super scary when you are working with a very expensive piece of ply!  The tip to do all the face plungesd first is really smart.  You can make mistakes with them being too shallow, but too deep is big trouble!  I made sure after I set the Domino down I automatically changed the depth to 12 if it wasn't already.
Rob
Glad you are getting it all worked out!  Domino has a learning curve , especially since it is more finicky and precise than a biscuit joiner. But after a few more uses you will get real comfortable with it and then it just becomes the way to assemble.
