dinkjs said:
Lets keep this in the Cabinet and or built in department only. So I was contemplating this question while in my "office" and looking at my cabinets and sinks in there. So those of you who use the Domino and or Kreg Jig (have to own both....that is the criteria in this question!!!!!!) At what point do you switch from Domino's to Kreg jig? I guess looking at my own bathroom I would use Domino's because of the smaller quantites I would use. And if it were a bigger job I would switch to pocket holes. So those of you that have both how do you determine to switch over to the other option in building the box and to the face frames?
Although at times during my long career I made more money from my other business enterprises, since 1949 I have always approached cabinet making as a business. In the old-pre Domino Era, I used the Kreg pocket screw system to the extent in my previous shop in Pasadena I had a full-on electro-pneumatic Kreg production machine.
However, even before I bought my first Festool I found that my clients would not accept pocket screw joinery. So, I sold my last Kreg equipment and have never regretted doing so for a second.
We do use Dominoes where to us it makes sense and is also within spec for a job. All of my cabinet makers know how to use Dominoes efficiently. All of can use Dominoes to make drawer boxes. We all also know how to as effectively make dovetail drawers, which with our clients is a far easier sell. Given the modern glues we use I am sure the wood will fail elsewhere but I make what the client wants and pays for.
Of course the advantage to the builder is with pocket screws you do not need dozens of cabinet clamps or several electro-pneumatic cabinet case clamps. Once your volume increases enough to justify those machines then you see a savings without the cost of the pocket screws.
Same goes for assembling cabinet doors. To a certain extent it is possible to insert plugs to hide the pocket screws, which works better when the doors are painted. Clients buy from us when they want custom cabinets with exotic veneer. Certain kinds of doors and drawer fronts can be made neatly using hidden Dominoes. Others call for cope and stick profile routing. Either way we will be using electro-pneumatic Doucet door assembly machines.
So, maybe there still is a place for Kreg pocket screws? Not in my business, but as we say, your mileage might vary.
