Domino XL EV/32 - Yew and Oak Epoxy Resin Table
grayedout
I thought this may interest any Domino XL owners , I have started working on designs for table using the Domino XL EV/32 connect to be able to flat pack for shipping , I am really happy with early projects.  the furniture if not everyday use more for display design over function as this point . but found the Domino XL EV/32 connects work really well
I found your video on YouTube, it was even better to watch this time! Your 80 20 assembly table is awesome! I need to move on making a couple of these... Thanks for your share, my friend.
Sent from my Pixel XL using Tapatalk
Nice design...Nice job... [thumbs up]...really like the flat-pack idea. Those connecters seem perfect for this application.
Questions:
Did you take 5000 polish to the entire table or to just the epoxied areas?
I've never been able to get a standard heat gun to work, I've always used a torch. Is that gun special in some manner? What's the temp or watt rating of the gun?
Thanks for posting.  [smile]
Really enjoyed the video - very nice work.
I particularly liked your use of the Domino for joinery where the legs meet the top - nice jig, and it gave me a few ideas.
Nice 80/20 tables and MFT style tops.
I found the setup for the epoxy fill educational.  I've done small epoxy fills before using metal ducting tape for backing, but never anything as large as this table.
Yew is listed in the wood database as being a direct cardiac toxin, so I've stayed away from it.  The wood database toxin chart doesn't distinguish European yew from Pacific yew, just citing the genus of both - genus taxus.  The individual articles on both describe them as toxic.  Did you take any precautions or notice any symptoms while working on this project?  I know it's kind of a crazy question to ask, but I'm finding that the older I get, the more sensitive I am to dust - seems to be causing more respiratory problems.  I'm fighting a cold at the moment whose onset coincided with a long koa sanding session, and koa is considered to be pretty benign, and the last 2-3 colds I've had have also coincided with sanding sessions.
What is the trim router that you used in the video?  I've never seen one shaped like that before.
rvieceli said:
[member=44099]Cheese[/member] another option is to use a vacuum pot to degas your epoxy before you pour.
Thanks for that Ron...I never knew they existed.  [eek]  Another job for the Vac Sys... [smile]
