Domino XL Technique
Erich
I do not think that this has been discussed here yet, so here goes.
I was reading the piece in the new (Oct. 2014) Fine Woodworking entitled "Domino Changes the Game" and I came across a photo on page 74 that caused me to do a double-take. The author is demonstrating how to "properly plunge" with the Domino XL. In the photo he has his hand cupped under the rear of the tool and the caption says, "Push from the back of the machine, not the handle." On the next page he is using the tool in what I had assumed was the proper method, one hand forward and down on the fence handle, the other firmly gripping the rear handle.
I own both Dominos.  I have used the Domino 500 for a number of years and will admit to having had difficulties in the beginning with my technique.  After spending some time on the phone with the application specialist at Festool USA, I learned how to properly handle the tool.
I have yet to start the first project utilizing my new Domino XL. However having test driven the tool at my local Woodcraft I thought that I had a pretty good handle on its use.
My question is this. Which is the proper technique for using the Domino XL?
I've been to training at Festool USA in Indiana.  The instructions i received "were all pressure on the handle of the fence, then guided the plunge straight in lightly from the rear".  Basically grab the cord and lightly push forward to make the mortise.  It sounds like the first description you gave is the correct one.
For the XL I alternate hand grips on the rear hand. I will use the handle of it is a short plunge. And I will do the cup hand on the lower rear of the handle for deeper ones.
I will also use my hip and hand sometimes. You will just get a good feel for what is right and produces good results.
Cheers. Bryan.
When it comes to "technique", the ultimate goal is simple......a straight smooth plunge while keeping the domino (500 or XL) from moving/rocking on the piece you are cutting the mortise in.  Whichever way this is best achieved I think can differ from one individual to the next, so, while Festool can illustrate methods they have found works best for them, it still comes down to how YOU best handle the tool.  Body position, hand position, no body movement, however you achieve the best results, whatever works best for you......  Time and experience with the tool will help hone your ability to achieve the best results.
I have to comment I find it ironic that Festool is know for superb engineering and ergonomics yet a number of the tools are best operated by not holding them by the handle.  [wink]
+1, first the RO90 and now the Domino XL
I completely agree with Baremeg...Whatever works best for YOU is the proper way to use YOUR tool.  HOWEVER you can achieve a perpendicular plunge is correct.  I have used my hip before plenty of times and and achieved "perfect" results using nonstandard technique.  I believe the training is attempting to teach how little pressure is needed to make a good plunge.
