D darita Member Joined Jan 23, 2007 Messages 462 Sep 2, 2015 #1 I'm going to butt join a 1/2" thick shelf into a 1/2" thick side board and I'm wondering if I can use Dominos and if so, what size?
Shane Holland Festool Dealer Member Joined Jan 22, 2007 Messages 11,163 Sep 2, 2015 #2 darita said: I'm going to butt join a 1/2" thick shelf into a 1/2" thick side board and I'm wondering if I can use Dominos and if so, what size? Click to expand... Yes, use 4mm tenons, which are the equivalent of 5/32". So, that's roughly 1/3 the thickness of 1/2", which is the rule of thumb for tenons.
D darita Member Joined Jan 23, 2007 Messages 462 Sep 2, 2015 #3 Maybe a dumb question, but does the length matter, since it's going into a 1/2" thick side?
Shane Holland Festool Dealer Member Joined Jan 22, 2007 Messages 11,163 Sep 2, 2015 #4 darita said: Maybe a dumb question, but does the length matter, since it's going into a 1/2" thick side? Click to expand... Brain fart, Tom's right the 4mm cutter is too short to blow through 1/2" material. Note that the 4mm cutter is shorter than the other cutters, so adjust accordingly because the depth gauge will be inaccurate.
tjbnwi Member Joined May 12, 2008 Messages 7,133 Sep 2, 2015 #5 darita said: Maybe a dumb question, but does the length matter, since it's going into a 1/2" thick side? Click to expand... The 4mm will only plunge 10 mm deep. You set the Domino on 20, the cutter is only 10mm. 1/2" is about 13mm. Tom
semenza Festool Moderator Festool Moderator Joined Jun 24, 2007 Messages 10,383 Location Fingerlakes Region NYS Sep 2, 2015 #7 darita said: Got it. Thanks. Click to expand... I am curious about the shelf and how much weight will it hold, and will it be edge glued to the sideboard, etc? Seth
D darita Member Joined Jan 23, 2007 Messages 462 Sep 2, 2015 #8 It's a pretty simple shelf/cubby unit that will be holding some antique clocks that aren't very heavy. I'm using a driftwood stain to make it look like weathered wood. It's all cheap pine. Construction is very simple.
