Drainer jig uk
Mahomo59
Have two oak Worktops to install both with Belfast sinks. Can anyone recommend a suitable drainer groove jig. There is loads out there, with a huge price range. Looking for advice on what others are using, better to go with recommendations.
I have the trend jig if you were closer you could have borrowed it.. One thing be very carefull about setting the depth of the cutter take some shallow passes off some scrap material till you are happy with the result..
I have the Unika one ( got it from Screwfix IIRC ).
It does the job fine, and I have used it on Solid timber tops and also on Solid surface material.
