Drill Perfect Holes With The New UJK Technology Drill Guide
I have a similar version. I haven't used it much, but my recollection is that it is a great workaround when a drill press isn't practical or convenient.
Growing up I remember seeing one of these under my dads workbench.  He had only necessary tools given the times.  It nicely enabled him to drill holes drill-press style without having a drill-press.  This unit looks a lot nicer than the one he had.  Recalling his usage issues, the biggest challenge was keeping the unit in place as you're drilling the angled hole.  If you can clamp it to the object it works well.  If you think you'll hold it in place with that handle I suspect it'll end up where my father left his (under the bench).
Since I don't need to be mobile, this is one of the tools I just have no desire to own..
Sent from my iPhone using Tapatalk Pro
I have a similar style guide, which I've used a bunch. It has tons of slop, and also also vibrates quite badly while in use. I would really love a press, but I just don't have the room. I suppose a guide is better than nothing, but mine is definitely not great.
This one looks nice and solid. The clamping/attachment options are also interesting. That's something I've struggled with as well, particularly when using at angles. And, a centrotec-compatible shank really adds to the convenience. Would prefer a ratcheting chuck, though.
I'd love to give it a shot - any one know if it is available in NA?
If its the one from Rockler I have it and yeah it's very sloppy, I can free hand as well.
I would love to check this version out, it looks solid!
The only one on that list worth buying is big gator, I have tried them all and still own at least 3 of those models.
Make it 4 for Big Gator...I also have their ANSI tap guide, it's slick.  [cool]
Thanks for the heads up regarding Big Gator...just ordered the two sets going from 1/8 - 1/2.  I should have had them the last two days as I installed two steel entrances and they would have been mush better than the eyeball and square method for installing the hardware.  [unsure]
Be sure to check Amazon for Big Gator drill guides.  They're less expensive there.
I have a similar guide to the gator one but is a type of plastic with steel inserts.
Anyone know of a supplier for those type of plastic storage tubes as I need some preferably in the UK? What is thete proper name so maybe I could do a search?
Cheese said:
Google Beckett Packaging or
End mill storage
Cheese , thank you. Just what I was looking for. Now I have to see if I can buy from them without the minimum quantities😕
Ya, the Beckett Packaging info was just to get you heading in the right direction. The real issue as you've stated, is finding a source to purchase small quantities.  [tongue]
