rvieceli said:The gear box under the front pulley needs to be checked for gear oil levels.
Cheese said:rvieceli said:The gear box under the front pulley needs to be checked for gear oil levels.
So is it like a British motorcycle that wheeps incessantly, or does it just need to be topped off?
From what I understood. The slight weeping seals like this was often a "feature" of these machine designs. The accumulating oil on the shaft can be wiped easily and allows the shaft as well as the contact surface of the seal to be kept clean from dust with very little effort.rvieceli said:Yes and yes.
There's a seal at the bottom of the gear box that the drive shaft for the quill goes through that weeps ever so slightly. To replace it requires more dis-asembly than I want to do since it works perfectly. I'm also not convinced that a new one wouldn't do the same thing,
Ron
mino said:rvieceli said:Cheese said:Yes and yes.
Ron, you're probably right...installing a new o'ring will probably still allow it to leak. I had the same issue on the tachometer drive cable and the only solution was for me to machine the housing so I could install a double lip seal, which I did...hasn't leaked in years. [big grin]
Now that's funny...spoken like a true British motorcycle manufacturer. [big grin]
Bob D. said:Still disappointed the parts to perform the upgrade are not
available. But maybe I will come across them someday.
Bob D. said:Just make one model with the better headstock assembly and offer a choice of table when ordering. There
are so few part differences I don't understand why they dropped this.
Added link to this 3 part video series but it's moot since the parts are no longer available.
