nickao
- Feb 24, 2008
NO Router Table Top just the cabinets. Pristine.
Specifications:
Cabinet is constructed of solid wood core Oak veneer panels. This material is not common plywood, it is solid wood laminated on both sides with Oak veneer, very strong! Inside shelves are mdf. Extra beefy Oak face frame around the door and under the bit drawers are not just applied to the front they are rabbeted into the case to actually become structural members to help support the interior construction and the added weight of the stored router bits, eliminating the possibility of sagging which could lead to the door and drawers binding.
To make the unit mobile simply replace the leveling bolts with threaded stem casters available thru most home centers and hardware stores. Total height to table surface is about 35"(depends on your top thickness).
2 drawers hold 36 - 1/2" bits, 2 drawers hold 36 - 1/4" bits and 1 wrench drawer. Lower storage drawer is mounted on KV roller slides and large enough to hold several routers. The side 2 " quick-connect dust port draws dust through the router compartment while ventilating the router motor.
On/Off switch for the Router is front for easy access. Recessed for safety. 120-volt receptacles in back. Equipped with 6' Power cord.
The Bases I am selling do NOT have two switches on the front like in the picture, only one.
These can not be broken down so the shipping is close to 75.00 anywhere in the USA.
PM me or ask questions in this thread. I do have CMT router table tops for sale with the Inserts and one CMT fence, they are expensive, but worth it. I felt someone may want the base so they could put their own top on it. If you are interested in the router top and/or fence let me know.
I purchased two of these and set them back to back. I was going to set them on a plywood platform with wheels as a single unit and place a CT in the middle(perfect fit). Then you would have a rail and stile router set up for cabinet doors. I am willing to strike a deal if someone wanted everything.
I never got to it and the bases just sat.
150.00 each. FREE PICK UP or Actual cost of shipping.
Nickao
Specifications:
Nickao
