hopper said:
Would an ultimate dust devil be effective in removing the dust before it got to the filter? Has anyone tried it?
Hi Hopper! I have an Ultimate Dust Deputy from Oneida, and have used it on my CT-26 and ASR 35 ACP vacs with great results for wood dust.
As a residential remodeler, I find myself producing concrete, stucco, plaster, and drywall dust almost as often as I produce wood dust. My original intention behind getting the Dust Deputy was to pair it with my CT-26 to act as a prefilter when extracting cementitious dust. In my experience, the Ultimate Dust Deputy does seem to live up to the manufacturer's claim of capturing 95%+ of the dust. HOWEVER, the dust that did make it through seemed to be extremely fine, and seemed to saturate the pores of the fleece filter bag in my CT-26. So, performance would drop, even when the fleece bag was only 1/4 full. That, and in a on-site setting, the Ultimate Dust Deputy/Vacuum assembly was a bit awkward to move from room to room.
Ultimately, I've decided to reserve my Ultimate Dust Deputy for applications where I am producing EPIC volumes of wood dust in a single day (for instance running a thickness planer, performing extensive ripping operations, etc...), where it is hooked up to a bench top tool and there is not an expectation that I will be moving the vacuum from room to room.
My CT-26 and CT-MIDI are now reserved for processing woods, plastics, metals, anything non-cementitious.
For processing cementitious dusts (stucco, plaster, concrete, drywall, brick, mortar, tile, etc....), I have purchased a vacuum that is specifically designed from the ground-up to agitate the filters to release the dust. The downside here is I don't get to open the vac to reveal a nice, clean interior. The upside is these vacuums can extract just about anything you throw at them, but I needed to learn to tame my OCD a bit about the interior cleanliness of the vacuum.
For drywall, check out the CT-36 AC. If you need a HEPA rating for Lead projects, check out the Starmix ISP series vacs (here in North America, these are offered by Metabo as the ASR 35 ACP for ~$750, or a more fully featured version from Rokamat called the Tapir for ~$1500), or the new Makita vac would be a great, relatively low cost option as well.
