mino
- May 5, 2016
Yes I did ... how would I know.Coen said:Have you tried? I wouldn't expect it to blow out stuff through the inlet. But without the hose, the pressure in the tank won't be as low as with hose, so the air burst won't be as effective either.
You remember the CT 22? It has a handle to 'scratch' the filter. Absolutely useless lol. You also have to completely remove all cable from the cable wrap to use it.
Though "do not like", it was probably the wrong idiom.
Without a hose attached, the reverse flow passes the hose port and some dust will be thrown out. With normal use this is "absorbed" by the underpressure in the system. Nothing too crazy though and not sure why one would run a vac in AC more without a hose ... I was just curious, playing with my new toy. Heh.
Main point being, the AC function is -not- a replacement for the "manual cleaning" function on some of the non-AC vacs on the market. Unlike manual cleaning, it is actually harmful to the bags and unneeded with a SelfClean bag. There is a reason no manual clean option is included on the CT26/36/48 series.
