Chris Billman
- Jul 14, 2008
My next Fe$tool purchase will be either the DTS400EQ or the RTS400EQ orbital sander and I'm having a hard time deciding between them. I've demo'd both, had sales reps recommend both, and I've read thru search results here and on other forums. My intended use will be to replace my 1/4 sheet sander for tasks like final finish sanding prior to finishing and fine sanding between coats of finish.
If anyone has comments about why you'd choose one vs the other I'd love to hear them. I'll probably eventually end up with both (or the parts to change them over), but it may be a while till I can do another sander and all its papers.
Also, Festool USA's website lists the two sanders with different orbits - 2mm on the DTS and 3mm on the RTS (link). Is that correct, and if so does it make one more suited for my uses than the other?
Thanks in advance for your help.
