James Watriss
- Mar 4, 2008
So, after having used the edge guide a few times before, it finally dawned on me today why the rods are so freakin' long.
I was running a groove in the edge of some 3/4 1A ply for edge banding. I've used the edge guide before, I dig it, but I do hate having more than half of the router hanging over the edge. Dusty floor, 8' long run with a slot cutter...
The slot cutting bit does have a bearing, but it occurred to me that the edge guide might provide a little more stability. Then after it was all hooked up, it dawned on me that with the rods sticking so far inboard, that I should see if I could use one of the guide rail blocks as a makeshift offset base, to really stabilize things.
Sure enough, works like a charm.
I'm sure I'm not the only person to figure this out, but I figured I'd share, to help the other pinheads like me who took a while to get it.
