Quote from: tallgrass on October 02, 2018, 12:57 PM
I really would be surprised is there is any real world difference in the "efficiency" in these separators.
I really would be surprised if there wouldn't be any real world differences in "efficiency".
Here some background information on the reasoning behind my expectation.
« Last Edit: Yesterday at 03:13 AM by Gregor »
That is very interesting. Fairly straight forward boiler plate information. Very informative if one is looking into these and trying to understand how they work.
However what is over looked in your source material is that these are not real integrated systems. What we are discussing here is not an integrated system that is engineered to meet certain specifications. What were are looking on is a an augmentation to an existing vacuum, or dust extraction system. These systems are not going to be used in an optimized environment. As such they are a general solution. The one advantage that Festool has is that their system is designed to operate with a given set of dust extractors. This will allow the appropriate design that matches their machine specs. This is in contrast to the dust deputy that has to work within a range of possible dust extractors. Which they do quite ably.
I am not suggesting that there will not be differences in efficiency, rather that the nature of their utilization will not render these differences meaningfully noticeable. What is more, how is the end user going to appreciate or even notice this? What will the nature of this increase or decrease represent in a mixed bag of saw dust and shop crud? Considering that a truly optimized solution is optimized to deal with a particular environment. None are magnificent across all condition.
I understand the consequences in the industrial environment. Where specifications of performance can be measured and adjusted for. In the portable environment the design is so compromised In favor of size that I truly think there are to many variables in play to really fuss over. For example, simple humidity variations could cause issues depending on what separated. Sanding vs sawing, the mass differential alone their would be an issue, if one was hunting for a "%" of efficiency. .The physics of these separators limits what can be achieved. How would you even translate a 5% variation?I am an engineer, I get going down the rabbit whole of the math and theory. In this case, however I think it is a forest for the trees. We are talking about bring the benefits of a separator to an existing ecosystem of extractors. I would bet the benefits far out way the the compromises. Pick the system that suits you and enjoy.
don't let this stop anyone from trying to quantify the efficiency across all work shop environments and dust extraction media. I would actually find it fascinating. [big grin]
