Using the MFK 700 EQ/B Edge Router in hortizantal position. I’m getting intermittent removal of the melamine surface. Should I just lower the guide plate to reduce depth of cut? Or any other tip that can be shared?
Thank you. I noticed I had the bit a little wider then the edge banding thickness. Do you typically set the bit exactly the thickness of the edge banding? In my case I’m using 3mm edge banding.
Which base are you using, the 0 degree or the 1.5 degree? You can have more issues with the 0 degree base. Use Tom's suggestions and run test pieces before wrecking a good piece.
