Has there been any study regarding deflection on edge joined boards? When designing a shelf unit recently I was using sagulator to project the amount of sag that would occur with 1 inch thick shelves 36 inches long by 11 1/4 wide. The wood is african mahogany. The shelf will be supported by medal paddle supports - 2 on each end and ??? across the back (that's what I was trying to determine). Sagulator does not address that but does anticipate using a lip. Based on sagulator the expected weight should be supported adequately but what if I am wrong about the weight to be supported? So then I got thinking about the fact that I typically make shelves out of three pieces edge joined together using dominos. Would that not make the shelf piece more rigid and less likely to sag than a shelf made of one piece of wood the same size? Does anyone know of any fact based guidelines for this?
Thanks in advance
Thanks in advance
