My current project required edge-to-edge joining of two 3/4" plywood panels, each about 4 feet long and 4 feet wide. This was to end up with a 4 x 8 sheet with the grain running across the panel instead of along the length.
Easy with the TS55 and guide. I just clamped the two pieces with the edges to be joined tight to each other, positioned the cut line of the guide so that the saw kerf would take out a small amount from each piece, and ran the saw thru. A perfect joint that is nearly invisible.
