Edge routing clamping fixture
Richard/RMW
I needed a jig/fixture to clamp stock that left the top totally clear and to let me route the edge without any obstructions, & I wanted the edge of the stock needed to overhang the fixture. After fiddling around a bit I came up with a simple jig using a piece of 80/20 (what else?) and a couple 1.5" squares of 1/4" plate. The key to the whole thing is that everything is below the top of the stock so nothing obstructs the router.
[attachthumb=#]
[attachthumb=#]
The 2 small squares of AL attach the the 80/20 with tee nuts/cap screws. At the right end there is a block of AL that is threaded and a handle to put pressure on the AL square. Both squares are beveled to give them a little bite into the end of the stock. The left square is adjusted by sliding it to fit the stock length.
[attachthumb=#]
The right square is left slightly loose on the 80/20, the handle is tightened to press it against the stock, and then the cap screw is snugged down to lock it in place.
[attachthumb=#]
[attachthumb=#]
Shown here I can route the edge of narrow stock with a slot cutter & nothing gets in the way. It takes less than a minute to swap out pieces of stock.
[attachthumb=#]
[attachthumb=#]
More fun with 80/20...  [big grin]
RMW
Andrew,
Seeing the Peachtree stuff was kind of a "duh" moment for me, I used to have one of the those clamps and totally forgot that they were available. Back when I had it (no idea where it got to...) I never had a use for it so it just hung on the wall.
Thanks for pointing them out.
RMW
Love seeing your jigs, Richard.  Very ingenious.  Thanks for posting this type of thing.  I think your design has used for jigsaws too.
Scot
