AlexThePalex
- Nov 12, 2008
Toddlers, haunted house ..... same difference. [wink]
To be curious, where's the point in that thing?Sparktrician said:ryanjg117 said:I had an electrician swing by a few months ago to add an outlet for a new gas fireplace insert. He mentioned he could replace our aging main panel with a new SqD 200a box, all up to code with a mains switch off and GFCI, for something like $1,200. A good deal for the Pacific Northwest?
Suggest that you check out the Leviton Smart Load Center. This is a game-changing revamp of the traditional load center which offers plug-in breakers with all wiring done on the backplane, not to the breakers directly. [smile]
Sparktrician said:Suggest that you check out the Leviton Smart Load Center. This is a game-changing revamp of the traditional load center which offers plug-in breakers with all wiring done on the backplane, not to the breakers directly. [smile]
JimH2 said:Sparktrician said:Suggest that you check out the Leviton Smart Load Center. This is a game-changing revamp of the traditional load center which offers plug-in breakers with all wiring done on the backplane, not to the breakers directly. [smile]
Thanks for the heads up on this product. I am building a new home and will be going with this panel. I had my mind set on a Generac GenReady panel with a built-in transfer switch, but I can integrate the generator with a separate switch.
mwolczko said:Sparktrician said:Suggest that you check out the Leviton Smart Load Center.
I wouldn’t get this. The life of a load center should be measured in decades. What is the chance that there is a functioning app even 10 years from now, much less after that?
Many companies are underestimating the support costs for apps (I’m in I.T.), and then abandoning their products (that’s a generous interpretation; I suspect many know darn well their product’s life is short). E.g., the first wave of net-connected security cameras has already been abandoned, after just 5 years (eg Logitech, INSTEON).
The only sustainable business model is to charge an annual subscription for the app —and even that didn’t stop Logitech dropping its cameras. How would you feel about paying 20 bucks a year to keep your load center going? Even at that price they’d need tens of thousands of subs to cover their costs.
Not having to have all the neutrals tied to a breaker and then the bus bar with the required AFCI and GFCIs in the latest codes does seem like it would make a much neater installation.JimH2 said:mwolczko said:Sparktrician said:Suggest that you check out the Leviton Smart Load Center.
I'm not overly concerned about the app as I know it won't last unless they sell a ton of units and even then 10 years could be a dream and 5 might be more realistic. I like the ease of wiring and that is the only reason I am considering it.
Gregor said:To be curious, where's the point in that thing?Sparktrician said:ryanjg117 said:I had an electrician swing by a few months ago to add an outlet for a new gas fireplace insert. He mentioned he could replace our aging main panel with a new SqD 200a box, all up to code with a mains switch off and GFCI, for something like $1,200. A good deal for the Pacific Northwest?
I'm from germany, a load center here gets wired once, by a professional and noone touches them from then on, ever...
RussellS said:ryanjg117 said:I had an electrician swing by a few months ago to add an outlet for a new gas fireplace insert. He mentioned he could replace our aging main panel with a new SqD 200a box, all up to code with a mains switch off and GFCI, for something like $1,200.
That seems expensive to me. The electrician is NOT rewiring any of the wires running throughout your house. He is just unhooking all the wires that are already at the panel. And hooking them up to a new panel. If your current panel works, what are you gaining from a new panel? You could add a subpanel right next to your current panel and get more space for breakers, if that is your main reason.
jonnyrocket said:RussellS said:ryanjg117 said:I had an electrician swing by a few months ago to add an outlet for a new gas fireplace insert. He mentioned he could replace our aging main panel with a new SqD 200a box, all up to code with a mains switch off and GFCI, for something like $1,200.
Not knowing the specifics of where you live or what is involved, I can say that I live in Oregon and that price is pretty reasonable. I just replaced a panel for a friend who bought an older house. The list of parts needed to do the job for a 40 space panel and 30 circuit breakers was $500 from Home Depot. Not to mention the roughly 6 hours that it takes to do a nice clean job on something like this.
I haven't worked full time as an electrician for 14 years now, but that price even back then was about right.
If you are in the Portland metro area, that price is pretty low as much of the larger industrial jobs tend to drive all prices higher than if you live further out.
A mains switch off and GFCI ?RussellS said:If your current panel works, what are you gaining from a new panel?
Gregor said:A mains switch off and GFCI ?RussellS said:If your current panel works, what are you gaining from a new panel?
Legislation here in germany is that you can keep electrical systems (within reason) as-is as long as you don't touch them, but the moment something is modified the whole system has to conform with the current regulations at completion.
This has up- and downsides, an upside is that problems don't accumulate (as they get removed whenever the system is touched), the downside is that some people are cheap so they skip maintenance (or installing a GFCI) as that would force them to redo a good part of (or the whole) deathtrap that is their current electrical system...
No idea how it works in other places.
