Holmz
- Oct 11, 2014
greg mann said:Holmz said:Svar said:All proposed pattern bit approaches involve cutting the board on strips. Something I would like to avoid doing on a piece like this. The bench calls for a solid or a book matched piece.
At the traffic light I considered that if the arcs were on a template then they just go higher and the template does not need to be accurate for teh flats.
Just two arcs (or 3).
Very good point. Another approach could be to register the strips in a jig, perhaps on a piece of plywood and use a large circle jig to cut the arcs. The key to the flats is to not touch them with the router,IMO. No pattern needed.
I like ^it^.
One could even use MDF.
In your method one could have the circle jig hold a router and using the router's edge (The side of the bit) to get the arcs.
I got my forepaws onto the end of an RO150 the other day and got stuck into a band sawn slab.
It seemed that the removal rate of the machine made it difficult to have a flat piece. Is that my technique or would it be difficult to have a bench without waves using an RO150 ?
