GaryLaroff
- Sep 23, 2008
I?m new here and am not sure if you prefer I piggy-back off another stream or start a new one.
The question has to do with the ES 125 EQ and ETS 125 EQ sanders as I have an opportunity to buy a nice ES 125 EQ.
I do woodworking as a hobby in my own shop making mostly furniture and the like. The current project is a batch of rocking horses. So, unless I have to sand some wood on the entrance to my garage, the tools never leave my shop. When possible, I always use dust collection.
I already have four decent sanders for furniture, all of which are Porter-Cable models. For most work I use one of two PC 5-inch random orbitals. The single speed has a 1.9 amp motor and the variable speed is the 333VS with a 2.4 amp motor. I think both of these have 3/32 inch orbits. For some finer work or when a spinning pad isn?t convenient I have and use the tried-and-true model 330 ?speedbloc? and larger model 505, both of which are rectangular orbital sanders. The 330 has a 5/64 in. orbit. For the random orbital sanders I use the Mirka bulldog gold disks but expect to use the Brilliant and Mirka Abranet and Abralon if I buy the ES 125 EQ.
In postings over a year ago, the minor differences were listed for the ES 125 EQ and ETS 125 EQ sanders. Although I can?t find an ES 125 EQ user manual online, it appears to have a 3/32 inch orbit whereas the newer ETS 125 EQ has a reduced 5/64 inch orbit, which was not posted last year.
My questions:
1. Is the reduced orbit on the ETS 125 EQ noticeable or will the ES 125 EQ give the same results? I am not interested in speed or in weighing the amount of saw dust removed and am mostly interested in quality of finish.
2. I just bought a Mirka Abranet sample kit of one each disk from P80 up through P600 grit and will try it out on the PC 333VS. Have any of you used this abrasive on the E(T)S 125 EQ and how well did it work?
3. Considering the sanders I have and the work I do, do you see any improvement I will get with the Festool sanders or do you have any other advice or comments?
4. I will go to one of the local Festool dealers and try to play with the ES 125 EQ/ETS 125 EQ today. With the PC RO sanders I either hold them from the top or by the neck and have been told the vacuum port gets in the way of holding the Festool sander by the neck. Do you have any experiences with this or should I just check it out myself?
Regards and thank you in advance for any responses,
Gary Laroff
Portland, Oregon
My questions:
Gary Laroff
Portland, Oregon
