Well, being new to the Festool world I need your input. My first purchase was the RO 150 FEQ. Wow, what a sander. Anyway I added the ES 125. I like the size of it, but I'm not sure about the operation. It seems to bounce a lot unless I don't put any pressure at all. I know let the sander do the work, but I would like to be able to hold it against the work. Also it vibrates. One thing I have read about Festool is the lack of vibration when using their sanders. Right now I would rather use the rotex than the ES 125. The rotex seems smoother in ROS mode than the ES 125. I guess my expections are high after all the research I have done on Festool. The ES 125 does not impress me.
So, question is would the ETS 150/3 be a better choice? Does anyone have both of these? Do they work the same or are they in different leagues? The rotex will do everything, but I would like a smaller size sander for some applications. That is why I got the ES 125. Using the same size disk means nothing to me. I would only want the ETS 150/3 for using with higher grits. Any rough work will go to the rotex.
Thanks for your help. Any input or suggestions would be great.
Tim
Tim
