The hose you see in the picture is from the Festool Universal Cleaning Set and is non-antistatic. Besides being lots cheaper than an AS hose it is a lot more flexible, supposedly the new AS hoses are less stiff, but I haven't tried them yet. I would assume it's safe to use the non-antistatic hose otherwise Festool wouldn't sell it. I do notice that static cling causes dust to stick to the outside of the plastic hose sections from the set, but I assume that's because they are plastic.
I've standardized on a workshop cabinet size and the grinder cabinets (there are two of them in the picture) are that size. I make them from one sheet of 3/4" plywood with 1/2" ply for the drawer boxes, 1/4" for the drawer bottoms, and melamine for the top. The double locking casters I use are 100mm from floor to top of plate. I use 3/4" ply for the back and fasten everything together with dominos since it has to be structurally sound standalone. I make the doors and drawer fronts from one piece that I cut from the original piece of 3/4" ply and I make the cuts such that the grain matches through the doors and drawers (yeah, that kinda nuts). The drawer boxes are 100mm high, the drawer fronts are 130mm high. I use the LR32 system for the shelf holes and hinges. I've been lazy for the last few cabinets and cut the pieces for the drawer boxes including the through and stopped dados for the drawer bottoms on the X-Carve CNC.
I can't remember the other dimensions offhand, but if you like I'll post a cutlist (except for the drawer boxes) and CAD drawing sometime tonight/this weekend.
