I've had my ETS125 ROS for about a year and it has received very light hobby use. maybe a total of 6-8 hours of sanding time on it. Recently I've noticed upon start up and sometimes in the middle of sanding that it does something that is a mix of stalling/pausing where the random orbit action almost completely stops and then anywhere from 1-5 seconds later it starts sputterring and regaining movement/momentum and gets back to normal.
I'm running it with a festool mini, just doing basic sanding work of things like cutting boards, lazy susans, etc. my planer leaves a decent finish so most of the time I can start at 150 or 180 grit on my projects and i work up to 400 grit. I rarely use it with a 60 or 80 grit disc for aggressive material removal. I use a relatively light grip and almost no downward pressure, i'm not mashing it down on the surface.
I've checked the power cord connection to the ROS and the mini and the mini to the wall...no issues there.
Any ideas or thoughts on what it might be? Thanks for any input.
