I just purchased an ETS 125REQ sander. For the first couple uses, about 4 hours of sanding time, it worked perfectly. I could just rest my hand on the top and it would stay in one spot. It took little effort to move it slowly across the surface. I was sanding Baltic birch drawer parts batched and clamped on a bench top.
When I switched to sanding a cabinet that was already assembled and on casters, I started the sander on the top and it started jerking all around. At first I thought it was the cabinet being on casters and easily moved. I laid it down to sand the side and had the same problem. I tried different sandpaper. I did a web search and found out that I should not have been using the CT MIDI at full suction, so I turned it down to min. I tried reducing the speed on the sander. Finally in frustration I removed the sanding pad from the sander to check for anything that was loose. There was a lot of sawdust that I blew out with compressed air. I could not see any problems.
After reassembly, the sander mostly works. It still occasionally starts jumping around and at times I need two hands to control it. Most of the time it just has a consistent wobble/jerk at the same spot of rotation of the pad. I can also hear the motor sound change at the same time as the wobble. If I just hold my hand on the sander so it is staying in the same place it looks like it moves about 10mm for each wobble. The rotational speed of the pad seems to be roughly 120 revolutions per minute, so the sander is jumping about 2 times per second.
In addition, if I lower the speed from 6, the pad frequently stalls. I am not putting any downward pressure on the sander.
I hope that someone has a suggestion for something else for me to try.
The sander was a joy to use for the first couple sessions. Now it is not. In addition to the wobble, I have to always be prepared for the random times when it just goes wild.
